K. Walibora
10 points
Posted on - 08/23/2016
I want to keep an update of the events, meeting according to the dates. It is very stressful to manage and remember all the appointments. What are the free calendar programs for Windows?
Free Calendar Program : Romo, Interactive Calendar, Rainlendar.
1. Romo: It is a free calendar software for computers. It displays the calendar on computer and shows week, a day of the year, current time, etc. It helps to keep tracks of important dates and tasks.
2. Interactive calendar: It helps in managing appointments, and you can also plan your weekends using this.
3. RainLendar: It helps in adding reminders and scheduling tasks. It gives the alarm facility and allows you to make your to-do list. It helps in searching task and event and printing.
