Free css editor for Ubuntu operating system
Hello expert, I need free css editor for Ubuntu operating system. Please send the download link to download the software. And send some helping tutorial explanations for how to use that software, Special features, Main advantages and disadvantages.
Best Answer by Joseph S Peterson
Answered By 35 points N/A #157336
Ubuntu has a couple of default text editors, gedit and nano. Nano is an editor that requires the terminal to edit text including CSS but it is very hard to use. Gedit can be accessed from applications>>accessories>>text editor. Gedit is better than nano but lacks a lot of professional coding features.
You can download bluefish by typing the following command in the terminal,
sudo apt-get install bluefish
The best features of blue fish are, its lightweight, fast, FTP, code block folding, highlighting start and end block, auto completion and auto tag closing for many programming languages, CSS is included and many more. There are no disadvantage's for this editor.
Answered By 50 points N/A #157337
i understood your problems happening. As an expert i want to ensure you that editing on html or CSS could not be perfect. You can use Dreamweaver 4/ 5/ 6(DW). I recommend you to use Dreamweaver 5 for editing html, CSS, WordPress and this kind of coding system. It can help to remove the hazard of coding. It's easy to create html/css file. It would be helpful for you.
Otherwise if you want to convert your CSS file: http://css.brothersoft.com/css-editor.html?fromsearch this link can help you.
