Free directx r for warcraft
Hello guys,
Hello guys,
Hi Carol,
What you basically need is the newest DirectX version. Just hit Download button and then run it and it should install the newest DirectX automatically for you. Another solution is to download newest GPU drivers. But for this you need to know your GPU (graphics card) maker.
There's just two of them – NVIDIA and ATI/AMD. To find out what's your GPU, hit Start in Windows, then type device manager in search field. In Device Manager look under Display Adapters column, it should tell you what's your GPU.
If it's AMD/ATI then go here and do the same steps. Install the newest driver, restart your PC and you are done.
Hope this helps you.
Good day Carol
You didn`t say what version of Warcraft you are you are playing. The system requirements for the game is:
Check to see that you have the latest Direct x version installed on you pc do the following.
Press on your keyboard the window key + the letter "r" at the same time.
Type didiag in the search box and pres ok.
You can download the latest version of directx here:
http://www.microsoft.com/en-za/download/details.aspx?id=17431
Hope this will help you.
Notifications
