Free download of ccleaner finish
Where can I get the ccleaner Finnish version free download for my system? And the steps to install it.
Please anyone help me.
You can get it here http://www.piriform.com/CCLEANER , there's a free version there. As for installation it's this simple, run the Installer that you'll download from that link it will first let you choose a language to install it with choose one, click next then OK and you're done.
You can download it from here https://ccleaner.en.softonic.com/ , it is free. After completing the download then open the file. Now accept their privacy policies and click next. And install the full software. After completing the installation, a ccleaner icon will appear on your desktop. Click on this icon and select drive and clean your computer.
You can get it here: http://www.piriform.com/CCLEANER. There's a free version there. As for installation, it's this simple: run the Installer that you'll download from that link, it will first let you choose a language to install it with. Choose one, click next, then OK, and you're done.
I don’t think CCleaner is available in regional versions like in the Finnish version because its download page shows only one version. If you want to see CCleaner in Finnish language, you can change the program’s language used in the settings which defaults to “English.” Download the free version of CCleaner and install it.
Once installed, start CCleaner then go to “Options” on the left pane then in “Settings” on the right, change “Language” by selecting “Suomi (Finnish)” from the dropdown list.
After changing the language to “Suomi (Finnish),” the CCleaner interface should now look something like this:
And that’s it. CCleaner is now in Finnish. If you want to convert CCleaner to Pro, download the codes and follow the instructions.
