Free download of home block font for MS word 2000
Hello Techyv.com!
I have here a Windows XP laptop with MS word 2000, Now I have a project; and my project should supposedly be in home block font. Now my MS word doesn't have this font. Please help me where can I freely download this home block font for my MS word 2000. Thanks.
Best Answer by Maurice M Persaud
Answered By 30 points N/A #176674
 Following are the locations where you can download block fonts:
Dafont is the hub of major fonts. You can find the exact home block font here
You will get ttf file when you extract the zip file that is downloaded.
To install the ttf in Linux, follow the steps below:
  1. Open the terminal
  2. Type "sudo gnome-font-viewer <font-file-path>"
  3. Enter password and press enter
  4. Click install when prompted and the font will be installed.
To install the ttf in windows, follow the steps below:
  1. Go to Start > Control Panel > Fonts
  2. In the fonts window, go to File > Install New Font
  3. Browse and locate the font file and click ok, it will install the font.
Hope it helps.
Answered By 30 points N/A #176675
Hi Shane,
Well, for the home block font don't go randomly, just go through widely.You can hardly find the specific home block font, rather than there is a huge collection of MS word 2000 fonts and you can select your desired font's from them.
Just go through the links below.
1. Dafont it will help you a lot.
2. You can also follow this link.
Hope you could find your solution.
Answered By 55 points N/A #176676
You have to download the fonts by using the below link.After that you have to install them in your work 2000 and after then you can use them. You can download it free of cost but there are some of the fonts that you can use only after paying to the site.
Free fonts tagged blocks
Download Free Fonts
Here is the procedure of how you can install the font after downloading it from the above link.You have to follow the following steps.
1. Click Start menu
2. Click Control panel
3. Click Fonts (Which will be on the bar menu)
4. Click Install new fonts
5. Give the source of the downloaded file
6. Click Ok
