Micah Nandy
Posted on - 08/24/2012
This error always pops up whenever I run FDM, I use FDM as my downloader and it works great and fast with no errors except for this one but only when I run the FDM, anyone there also has this problem?
Error
Error in download groups
Ok
Free download manager error opening
I do not seem to know the solution to this program, but I think that the best possible solution to this for you is to delete Free Download Manager, from Control Panel go to Add/Remove Programs, and then reinstall the new version from here:
https://www.freedownloadmanager.org/
This solution seems to be the best one because programs like FDM seem to bug out here and there, and the best possible solution is to make a full re-install.
regards,
