Hello dear friends,
Where should I free download MySQL ODBC driver 64bit for Windows 7 that will work as a standard gateway for MS Excel & MS Access or OpenOffice. If I can get a free download link that will help a lot, also do the needful for advising me on how to Install and Create ODBC Connector using MySQL.
John B Garrison
Free download MySQL ODBC driver 64bit for Windows 7
Hello
You can find MySQL connector on official site of MySQL: https://dev.mysql.com/downloads/connector/odbc/
There is option to select which platform you use so you get best software. This connector supports all operating systems. Installation is simple, just download installation file and double mouse click on setup file which you downloaded. After that, follow on-screen instructions which will guide you in setup process.
Regards.
