frank logan
10 points
Posted on - 10/05/2012
I need office source reg fix to fix my problem of office source. The problem is in the reg files of office source. How can i solve this problem. If anybody have a solution or a URL of the software that can fix my problem please give me the URL.
Free download office source reg fix
I am not quite sure about which registry file you are talking about, but you may be referring to office source engine. If you are, then fixing it is really easy. Well, this file always makes troubles to its users, but anyway, fixing it will just be a walk in the park.
Here are some proven methods:
Method 1:
Use your MS Office CD.
1.) Insert the Disc to the Drive.
2.) Explore the Disc content.
3.) Go to FilesSetup, and copy Ose.exe.
4.) Paste and save it to your Source Engine Directory. Usually, it should be found in this directory: Program FilesCommon FilesMicrosoft SharedSource Engine
Method 2:
If the above method won’t work, then reinstall your MS Office Suite. That should probably make your Ms Office work again.
Method 3:
If you don’t have your MS Office CD, then use this download link.
https://e.4shared.com/linkerror.jsp
Paste it on the directory shown above.
I hope this helps.
>> Mathew Joni <<
