How to activate Route 66 Wave?
Route 66 wave is not free software. You can use this software as a trial and you can use it free as a trial version only for 30 days. On the other hand you can purchase this software. Just go to Samsung website and then type Route 66 on the search area and locate the purchase button from there.
Hello Canyon,
You have to buy the Route 66 wave software or you can try the trial version for one month. Now for activation you have to install the app at first then connect your phone in the mass storage mode. For your country or region this software will display you the available downloads. There you’ll find the maps which are free but you have to pay for the navigation. Hope this could be a help.
