Free Facebook download for Galaxy tab
Hello Techyv Experts, I have brought new Galaxy Tab and I need to have a free Facebook app in that. Where should I get a free Facebook download for Galaxy Tab.
Hi, if you have galaxy Tab operated by OS Android 2.1 , you can download Facebook application in Android Marketplace. You need to select: Market from your home screen, tap search, enter Facebook, and there you just click free download .Now you are able to use Facebook application on your Samsung Galaxy Tab.
Thanks!
Hello Perezlee Robert,
Facebook is the most popular and the most powerful social site. Right now, it is also the most dependable social site.
Here, you can get all of the things that you need.
There are many Facebook applications for the Galaxy Tab. The “Feeds and Updates” widget is the default application for Facebook, or you can use the default Facebook application for your Galaxy Tab.
Hello Robert,
To install Facebook on Samsung Galaxy Tab you have to locate Play Store from your home screen and Tap, if you cannot find this directly from the home screen go to Apps then Play Store and then Tap the search icon on the upper right side of the screen .Then type Facebook on the search field then Tap the search icon from the onscreen keyboard. Then Facebook for Android should appear from the search list Tap ‘Facebook for Android’. Than Tap the install button. Then read agreement then Tap the ‘Accept & download’ button on the upper right side. Then tap the open button. You can now then enter your email and password to login to your Facebook account.
Hope it helps you.
