Hello Friends,
Happy to share that I brought a new Samsung Galaxy Grand. Now I need a free Flash Viewer of Macromedia for Android phone Samsung Galaxy Grand. Is it available for free. If available, Please do the need for sending me a free trustable download link to me.
Thanks & Regards,
Gerardo Thomass
Free Flash Viewer of Macromedia for Android phone
Congrats.
I will help you enjoy the experience of that phone by suggesting to you some of the free flash viewers that are out there today. Just click on the links that i will provide you with and you will be good to go.
Flash plays small, fast multimedia buttons, as well as interactive animations, flying logos, and graphics created in Macromedia Flash/micromedia flash.
Adobe Flash Player for Android allows you to enjoy the internet's best rich multimedia content on your mobile phone.
Improved to give the best the Internet has to offer, Adobe Flash Player 11 shows a quantum leap in performance over previous versions.
Congratulations on your new Smartphone!
The easiest way to install the flash viewer is via Google play. Open the app folder on your phone, find the Google play app and run it. Tap on the search field on the top, enter the term "flash viewer" and tap the search icon.
You will get a list of available flash viewers. I would suggest you to use Smart SWF Player-Flash Viewer by Simplelife or SWF Player – Flash FileViewer by Issess.
Once you've located the viewer you'd like to install, open it and tap the option install. Your Smartphone will do the rest.
