Free Gmail exchange database name
What is the best gmail exchange database name software? Is there an available free software for that? Thanks in advance.
Hi
Google does not provide the name of any database. It is very risky for Google. Google only share very limited information for any task but Google gives the API which helps you to perform different tasks like using your Google account to sign up in your website, Google Maps etc. These APIs are very dependable and robust.
Thank You
Hi there: As we know Gmail is Google mail and Google keeps lots of backend information private. Hence we don’t know any database names that Google uses since Google doesn’t share it with any one. However if you need to query that database, you have the option of using the APIs (Application programming interfaces). APIs are like procedure calls that can be used in any code and return results in certain format. Details of how to use the APIs are available on Google website.
 Hope this answers your query.
