Free host vpn for online games?
I am an online gamer and recently the game I am playing is limited to my country. Could you suggest a free host vpn? Of course, it has to be clean. I don't want keyloggers or any of that kind on my pc.
Yeah, of course. Have you ever heard of Hot Spot Shield or Expat Shield? Even I use them from time to time, however, their ads are very annoying, but I have a way to fix that.
https://www.hotspotshield.com/
If you use Mozilla Firefox or Google Chrome, download a little addon called Adblock Plus:
https://adblockplus.org/en/firefox
After that, install Fanboys filters to it here:
Even if you're using IE 10 or 9, you can use Fanboy filters to block unwanted ads.
Following are the instructions to setup a free VPN connection.
You can visit the website http://freevpnhosting.com
Use following link to get VPN setup instructions as per your operating system.
http://freevpnhosting.com/how-to-configure-vpn
VPN Connection user name and password are also displayed on their homepage.
Hope you achieve the desired result with these instructions.
Good luck!
Notifications
