Free light XML editor with support for XML Validation, XML Schema catalogs.
Few days back, I have moved from working on iOS apps to working on Android and with this, I have moved from using Xcode to using Eclipse.
I like the Eclipse XML editor due to its features like xml validation, schema libraries linking, tooltips for CDATA documentation, and auto-complete.
However, since Eclipse is CPU consuming, I have decided not to use Eclipse for XML editing, and instead find something else that fits the needs listed above & most importantly it is light-weight.
So, can anyone provide me tips if are there any free, light xml editors and xml-schema editors available?
Thanks!
