Green Scott
50 points
Posted on - 10/05/2012
Where can I download safe and free MP4 converter for Blackberry Torch.
I can't seem to open some files.
I Google the error, and it says my files are not in right format thus I need to convert.
The converters I've seen are mostly for Curve and Bold models.
I tried it and it is not working.
Free MP4 converter for Blackberry?
Try the KingConvert Video Converter for BlackBerry Torch.
It has super fast conversion speed that can convert to MP3/ 3GP/ 3GP2/ AVI format. It can also merge video clips into one.
And it can convert almost all the video formats such as DivX, XviD, MOV, MPEG and a lot more.
Download it from the link and then run the installation.
Depending on your Blackberry make or model of the Torch Series, i would recommend you try and download the Leawo video converter which greatly supports conversion of files to mp 4 for most model phones, not only Blackberry .
Here is a great site i can recommend for you, its really user friendly with clearly laid out step by step guidelines you can follow to convert your files into mp 4 format for your Blackberry.
Hope have been helpful.
