Free online form widgets to embed in my blog
Hello Dear Friends,
Is there any online provider that will allow and promote free online form Widgets, which I am planning to embed in my blog. I don’t have too many technical skills, so I need a widget which will be simple and requires no earlier technical skills. Please guide me.
Thanks,
Geraldine Carr
Best Answer by Johnny Mrmarshall
Answered By 0 points N/A #138407
There are many websites, which give you the free online form widgets. All of them the FormLogix best.
You can add a free online form widgets in your site by following all of the steps one by one:
  1. At first you go to the FormLogix.
  2. Then you choose what type of form you want in your site.
  3. Select the Add to Website Button.
  4. A pop up window open which want your Email address and Color.
  5. You give your Email address and color and then press the Apply button.
  6. They give you a Url Code and a Iframe code.
  7. Put one of this code in your website.
  8. Now you can able to setup a free online form widgets in your website.
Now, Enjoy yourself.
Answered By 10 points N/A #198742
Hello Dear,
A web form widget is a small component like contact us form or email us form. We can easily embed into our website or blog by just copy and paste Html code.
There is a website “Zillow” which provides free widgets to web publishers and give the opportunity to add their interests in websites or in blogs. There is no technical skill required to add an online form widget.
Click here and learn the process of adding a form widget to the website.
There is another way of adding a widget in the website. Check this website, It has also free widgets.
You can also check this website for free widgets.
Hope this will help you.
