Free Open Source Time Clock Software.
I’m looking for free open source time clock software. It is very difficult to find free software. I do not want the ones with a free trial period of a few days. I need at least one permanently free software.
It is very difficult indeed. But after a lot of searching, I have found a few free open source time clock software which are permanently free and do not have a mere free trial. Here are a few of them;
1) CKZ Time Clock: – This software is for Windows. It is free, but only for three employees. You cannot get more than this for free. It lets you monitor your employees, check attendance, leaves and holidays.
2) Kimai: – It is one of the most popular open source time clock software. It is a very simple software. This monitors an employee’s work time and you can get a print out of the summary whenever required.
3) TimeTrex: – This software has no limits on the number of employees and time. It works for Windows, Linux and Mac systems. This has the same uses as the above mentioned software.
I think these should be enough for you.
