Free or demo version of Kaspersky Anti virus 11
Hi Friends,
Where should I download free or demo version of Kaspersky Antivirus 11 for my Windows 7. Please help me to find it as soon as possible as I am badly in need of that.
Hi Friends,
Hi David,
I believe I can very easily help you solve your question since it is easily solvable. The Kaspersky 11 Antivirus and even the later versions cannot be found for free unless you purchase a key or full version but you can download from the Kaspersky website.
Simply go to www.kaspersky.com/trials and click on the Antivirus version you want to download so as to install on your system, there are even several later versions of the anti-virus you can also install.
Once you download the version you want, you can then follow the prompts to install.
Ensure to update your anti-virus to enhance maximum protection and yours can also install the key if you have one.
I hope this solves your query.
Good day David,
An alternative to Kaspersky is Avast antivirus which is free. I have been using this for the past year. You get your updates daily if your online or stay online your get it twice a day. Why I also like this antivirus is the updates is small because I have a limited data plan, so I can use it for something else.
You can download it from https://www.avast.com/en-in/index.
There is Avg antivirus that is also free, it updates daily. You can download this here https://www.avg.com/en-us/free-antivirus-download
I hope you could use some of the info.
