Free registry error fixer like dllfilesfixer.
I have a lot of registry errors on my system as shown by dllfilesfixer. I think that it's true because my PC is laggy these days. I want to find a free alternative to dllfilesfixer. What are the best free software to correct the registry errors? Can I fix the errors manually?
Answered By 5 points N/A #191537
Registry files are the files that store important data of Windows. It’s very sensitive part and dangerous as well. There are lots of professional cleaners for registry fixing.
There are lots of registry cleaners but DLL Fixer isn’t free for lots of usage. Wise Registry Cleaner is one of the best and free registry cleaners and is being developed day by day. It provides good result.
Answered By 590495 points N/A #191538
If your computer is very slow and you think you have problems in the Windows registry, I guess the best tool that you can use is PC Tools Performance Toolkit. I’ve been using it for several years now and I don’t see any problem with my registry. My PC also performs very well because I perform weekly maintenance and using PC Tools Performance Toolkit is included in my routine.
Aside from fixing registry issues, it can also optimize the Windows registry just like when you are defragging your hard drive. If the Windows registry is optimized, it reduces system lags when starting a program. It also adds boost to the performance of the computer. To clean and fix the errors on your registry, select Clean Your Registry. To optimize or defrag your registry, select Compact Your Registry. See image.
Fixing just the issue on your Windows registry doesn’t immediately improves the performance of your computer. Aside from making sure that your registry is error free, you also need to maintain the fragmentation level of your hard drive. This means you need to defrag your hard drive regularly so that applications will open much faster.
