jhana marie
10 points
Posted on - 10/09/2012
Even for modern freelancers & article writers it's a bad issue, that normally one can't afford costly article batch spinning software. So i wondered whether there are any free services available there in the internet for jumbling & producing a new unplagiarized content out of the submitted articles. Any tips, links on finding such websites.
Free software for Article Spinning
Hello Jhana Marie,
I have compiled several free sites for you to browse, so you will find the best article spinner. You can try several softwares and choose which would be the most useful, most powerful and easiest to use.
Visit each site and select the software you want from the list.
Hey Jhana Marie,
You may download following article spinning software’s which are free of cost and easy to use.
The Free article spinning software’s are only designed to function in very limited way and they don’t provide the whole spinning functions that are normally used when we talk about spinning.
Most of times, they work for a very specific time period (trial version). But these spinners should give you a push in free lancing field.
I hope you get what you are looking for .
Thanks
