Free Software Convert PDF To Excel: Steps, Advantage, Disadvantage.
What does free software convert PDF to Excel do? How many files are convertible? What are the advantages and disadvantage? How does the feature of merging help us?
PDF To Excel Converter converts PDF file to Excel format. The user has to predefine the target folder. The user can also keep it to default. Conversion of one file is possible at a time or multiple files simultaneously.
Step 1: Select the files.
Step 2: Choose the Excel version.
Step 3: Click on Convert button.
It is one of the main features is merging. It allows merging of several files into a one PDF file. You can as well organize their order.
Advantages: Transferring of text or images is possible. We can change the color of the documents.
Disadvantage: It is a shareware version.
A PDF to Excel converter simply converts PDF files into Microsoft Office Excel format. The amount of files that can be converted depends on the service you are using if you are doing the conversion online. It is better to use an online conversion tool than install a converter on your computer.
If you need to convert PDF files into Microsoft Office Excel format, you can try PDF to Excel from Baltsoft Software. This is an online conversion tool that allows you to upload PDF files and convert it into Microsoft Office Excel format. This service allows you to convert one file only if you don’t have an account.
But if you sign up, you can convert unlimited number of files. Another online service you can use is PDF to Excel from PDF Extractor. This allows you to upload your PDF files from your PC or by URL.
