Free software with video recording
I am in need a sort of a desktop recorder. Can I get a download link for that? I need it to be free and live desktop recording in the background.Â
Hello Ashley Glick,
GOOD Day!
It would be better if you inform us about your operating system. Here i will suggest you about some software that can successfully remove your problem.
Download Camstudio to record all kinds of audio and screen activity on your desktop.
Download real desktop activity recorder for free for better capture and better activity from here. To provide you, your most needed things and help you out from all kinds of desktop capture and screen etrustsoft is providing their customers for all kinds of desktop and PC related task .
Get your Authentic software and best screen recorder from the above list
Best OF luck…
Hello Ashley,
I recommend that you download Desktop Activity Recorder from here
https://desktop-activity-recorder.en.softonic.com/
If you need a more powerful and sophisticated desktop recorder I recommend to tryÂ
http://www.totalscreenrecorder.com/
Total Screen Recorder has the quality of consuming very low level of CPU memory and gives an optimum result without affecting other applications.
