Free software that will convert Winamp files to VLC
Guide me to find a free software that will convert Winamp files to VLC. Please suggest a software that will support Windows XP.
You don’t actually need to convert your Winamp files for it to be played at the VLC media player. VLC is so comprehensive that it can basically play any media files no matter what format it is. It is actually the most popular and most used media player today due to its flexibility.
Your question sound confusing. Do you want to convert music files from your Winamp so it can be played on your VLC player? Is that right? You can play almost all file types in VLC. It can play various music and video files. However, you can try the Total Video Converter as it can play most of the popular file formats.
