Free Source Code for Creating Drop Down Menu
I want some free drop download menu source code. I want something simple, nothing complicated, and most of all, free. But I do not want free virus with it. Is it possible to get one for free and clean?
Johnny,
There are many sites around the web that will have codes for free. Most of them you can copy directly from the web page. That way you don't have to worry about downloading anything. Some of them do have entire pages you can download but I don't like doing that as it does tend to have signatures on the page which makes it useless for school purposes. Attached is a text file of a drop down menu. At the bottom of the page are 3 web sites that will have other examples.
http://www.leakbali.com/script/7/simple-css-dropdown-menu/
