Which is the most popular free VPN Client that will help to browse the web without fear. I am searching for a VPN Client that hides IP address and let me bypass firewalls. Will free VPN Geo Client meet my requirements. Will it work in both Windows and Mac. Else suggest me the most popular free VPN Client.
Free VPN Geo Client or alternative
Hi Gloriawburbage
Using Virtual Private Network (VPN) or Proxy Servers lets you covered when you are browsing on the web. What I really mean is, you are being protected because your IP address will be changed to another one. So you can surf freely and anonymously. VPNs are not just used with your computers. Now, it can also be used on your android devices or even in IOS.
I am also using VPN softwares in my computer and I will suggest you to use Hotspot Shield. It is free and very easy to use. Just download and install the software, then you can now surf anonymously. Here is the download link for hotspot shield.
Hotspot Shield by AnchorFree
Sometimes, there will be ads that appear above on the page. To prevent these ads, just install Adblock in your browser. Here is the download link for chrome:
Adblock for Google Chrome
I hope this helps.
If you are looking for a VPN, try PD-Proxy. When I was still using a VPN before, I subscribed to PD-Proxy. I think it last for about several months until I finally decided to let it go. The experience was pleasant though at times there are network issues regarding speed and unable to connect.
You need to create an account in the website and download the VPN client most importantly. If you want to check it out first without subscribing, you can use the free server but be patient because there are times attempting a connection is hard because of the number of users. Aside from that, you can also use a public proxy which works similar to a VPN client but without actually using a VPN client.
You use your web browser to access the public proxy server. Here are some:
A Wacky Weberworld PHP Proxy – been online for 3 weeks with 100 percent uptime. Server is located in the United States and features HiAn.
SSL Unblock Proxy – been online for two weeks with 100 percent uptime. Server is located in the United States and features HiAn.
Monster Proxy – been up for 3 weeks with 100 percent uptime. Server is located in the United States and features HiAn.​
Instagram Proxy – been up for 3 weeks with 100 percent uptime. Server is located in the United States and features HiAn.
Mablet – been up for 5 days with 99 percent uptime. Server is located in the United States and features HiAn and SSL.
