J.Ammy
50 points
Posted on - 07/08/2011
I am suffering from this error for the last 1 week and have searched for its solution through out the week but got no positive response from any one.
Though VPN nowadays, is very popular, Â still no one can answer this error.
The ordinal 318 could not be located in the dynamic link library
LIBEAY 32.dll.
As you can see, in the images given the error is of some ordinal318, which is the content of the library which is needed during the installation of FreeVPN.
I actually don’t know  what this error mean and why  I am receiving it. Â
I have attached this image, for clarity so, you can easily get to the root of the error by seeing it yourself.
I hope I will get some positive response this time.
Free VPN Ordinal Not Found Error
#. Is a common error, if you are using  a Windows Vista and Windows 7. Now here are some tricks and solutions.
FOR WINDOWS VISTA AND WINDOWS 7.
STEP 1. remove all wireless kit internet before you install VPN installer.Â
STEP 2. now do not double click your installer. just simply right click and run as administrator.
STEP 3. now installation is going on. after you finish install VPN there is a window pop up, now there are 2 choices of where you can  connect your VPN..  now select ( LAN INTERNET) LOCAL AREA NETWORK INTERNET.
STEP 4. Â now were finish with the VPN. lets go to your connection interface (internet kit) Â interface must be configure to another settings.
        #now run your interface (internet kit)
        #do not connect
        # go to tools-option-profile management
        # create new profile:       Profile Name: (ex. jaime net)
                                 Access Point Name: http.(name of the network interface you are going to connect).com
                                          ex. http.globe.com
        #  go to advanced:
                                 IP Settings  : static
                                 Authentication protocol settings: PAP        Â
                                 DNS Settings: dynamic
                                  WINS Settings: dynamic        Â
                                 and then   save > save > save > saveÂ
        #   done and re boot you computer
           run interface — connect  the new profile (jaime net) – now if you are connected
          run  VPN exe as admin and connect.  Enjoy your free net
FOR WINDOWS XP USERÂ
NO NEED TO SET UP YOUR LAN SETTINGS,Â
1. INSTALL THE VPN. Â Â
2. FOLLOW THE STEP 4
