My friend is using Print Agent for Exchange in his office, which seems to be a freeware auto print exchange server that allows to take print out of necessary emails and attachments automatically. I would like to know whether it’s a freeware. If so please advise me on how to install and how to work with it. If its not a freeware, please suggest me an alternative freeware for that.
Freeware auto print exchange server
Hello Cromwell,
Print Agent is not a freeware, however there are freewares for this operation and you can easily get one.
To install PrintFile, once downloaded from the website linked above, you need to unzip the file and double click the setup icon.
The installation process is straightforward and it will guide you through the process.
You will get all the information you might need on this website:Â http://www.lerup.com/printfile/
Regards.
