I have recently upgraded from windows vista to windows 7. I have had no problem with drivers or compatibility. I downloaded a freeware capture sound card to record songs from internet websites but I am facing a strange problem I am unable to save the out put on a USB. I researched a lot but cannot figure out the problem.
Freeware capture sound card output not saving to USB directly.
Try the following steps:
1. Login to Windows through the administrator account.
2. Run the freeware capture sound card from your desktop. If you do not have the icon on the desktop then create a shortcut on the desktop. To create a shortcut on the desktop, right click the program and click create shortcut, select the location of the shortcut as desktop. Now the shortcut will be created on the desktop.
3. Connect the USB to your computer. Make sure that the USB is recognized by the computer.
4. Now record the song and save it on your desktop. After you save it on your desktop, transfer it to your USB.
If the USB is write protected then remove the protection and try again.
