ton ytony
10 points
Posted on - 03/30/2013
Hi,Â
I need an immediate help. Is there any specific software called as mailbox for idevices?
 Iam using Apple iPhone 4s.Â
I need a freeware mailbox management for my mobile.Â
If you have please send the download link.Â
And send some helping tutorial explanations for how to use that software, Special features, Main advantages and disadvantages.
Freeware mailbox management for my mobile
Kindly try this app for your 4s.
Mailbox
By Orchestra Inc,
Check this image if the apps show of the requirements will fit to your 4s, then download to your 4s. Just go to your 4s market play and search this mailbox by Orchestra Inc. 1.2.0 version made for smarter and faster that makes mobile Inbox in the right place. Through these images you will learn how it works and how it helps you better mailbox use.
Hope this could help you.
Thanks,
ThomasÂ
Hello Ton,
It looks like you are in need of a mailbox manager for your iPhone. There are a few mailbox software available on the web and you can try using any of these. This software runs on all OS platforms so you don't any specific software for your iPhone 4S. I have a link for you from where you can download this software.
http://www.brothersoft.com/downloads/mobile-mailbox.html
You can try the Mobile Helper software because it has good user review.
I hope this helps.
