Hi experts,
I need your help to find out a reliable interactive room flash component. Where can I download. And of course it should be freeware and shareware. Please, give me information about it.
Thanks
Freeware or Shareware Interactive ROM Flash Component
Hi there user:
I suggest you to get the ToobPlayer if you really want a reliable Flash Component. Features could be similar to other ‘Flash Component’ you know, but not with its customization.
This player has five (5) themes to select. It also allows you to play YouTube videos, and with mouse wheel support (especially for seeking) and volume control as well. There are also several resize modes for videos, which I’m sure the most from its features you could like. And yes, it’s free. You can download it here. http://www.brothersoft.com/toobplayer-download-341625.html
Hope I did satisfy you with my suggested software.
Thanks for posting your query here at techyv.com. Feel free to post again.
Best regards,
