Freeware Software for Completely Uninstalling Oracle Software
I need an application that can uninstall oracle software. I tried to use some freeware but they did not work properly. Some files were not successfully deleted and caused some failure of registry. If you have experience in Oracle uninstall download, please help to share me the name of software you state it works well.
Thanks,
Answered By 0 points N/A #137397
What you are asking is pretty comprehensive and detailed but I have encountered the same problem before which is why I can help you. After removing it using software, there are bits that need to be removed manually. The software only removes the program but not the other data stored in your computer. I will post links that tackles the topic and gives a step-by-step process to help you.
https://docs.oracle.com/cd/B28359_01/install.111/b32002/remove_oracle_sw.htm
https://docs.oracle.com/cd/B19306_01/install.102/b14316/deinstall.htm
