I am using WinHex as my forensic computer software freeware. I downloaded the free trial first and saw to it that it was good to use. When I downloaded the paid version, the software started acting up. It wasn’t recovering data as it should be. What could I do with this?
Freeware WinHex Forensic Software Issue After Installing Shareware Version
May be there is a problem with the paid version, because the trial version works as a pre software as the trailar of a movie.So the full version of the software will work better than that trial version. Now as you are facing problem with the full version you can run the trial version for some period and than boot your computer for using the software. Thank you.
