George Wale
10 points
Posted on - 11/17/2011
Hi People from techyv! I am having problem looking dll file from the error message which is mswebdvd.dll,
I tried to copy same DDL from XP OS and paste it to system32, but the error still appeared.
How can I solve this one?
Thanks
RegSvr32
The module “mswebdvd.dll” was loaded but the call to DllRegisterServer failed with error code 0x80020009
For more information about this problem, search online using the error code as a search term.
Qibili
Freeway mswebdvd.dll error code 0x80020009
You're probably wondering what caused this error, in most cases it is Microsoft DirectX.This .dll file is used during gaming or other high-end graphical applications.Here are some solutions to your problem:
a) Restore your computer to an earlier date before the start of this problem.
b) Install the new version of Microsoft DirectX.
• You can check these points to solve your problem.
• Check that your files you are installing are not corrupted.
• See for any error in program while installing the software.
• You need to check the virus in your computer. If possible then run a full virus scan to your computer.
• Check for any possible settings you have made earlier and try to resolve them.
• Check that your program must full fills the system requirements. If possible then change you Direct x to the newer version of the program.
• You can see the DXDIAG version form going to RUN and then type DXDIAG. Here you will see all of your options available and make sure that your program full fills all of these options.
• Once you have done these all you will be able to solve your problem.
