FRS Application – MAPIUTILS.DLL was not found.
10 points
Posted on - 10/25/2012
Hi Experts,
I received an error message from the FRS of Twitter. The screenshot of the error message is as under.
It has failed to find some program. How can I get that program and how to install that?
Have you any idea for the issue? Please help.
Thanks in advance.
![MAPIUTILS.DLL was not found. Please make sure that the DLL is installed correctly](https://www.techyv.com/sites/default/filesx/users/Images/FRS-Application-MAPIUTILS-DLL-was-not-found.jpeg)
FRS Application
MAPIUTILS.DLL was not found. Please make sure that the DLL is installed correctly.Â
