while trying to install FS wizard on my system I am getting this error on my screen and unable to resolve this issue. Can anyone please help me about it?
C:usersmacalesterdownloadsFSWizard_v0.01.EXE The version of this file is not compatible with the version of windows you’re running. Check your computer’s system information to see whether you need an x86 (32-bit) or x64 (64-bit) version of the program, and then contact the software publisher.
FS wizard error on windows 7
This error seems to be associated with compatibility issues. It could occur if the system requirements don't match with the software requirement.
If you are implementing AD FS 2.0 runs on these Windows operating systems only:-
1. Windows Server 2008 R2 (64-bit)
2. Windows Server 2008 together with Service Pack 2 (32- bit)
3. Windows Server 2008 together with Service Pack 2 (64-bit)Â
So make sure your system is running on one of these OS.
If it is already running on one of these, then make sure to download the correct file related to the right operating system from the Microsoft download Center
Laz Zebbena
