[FSLB-363] -There is an error starting QuickBooks
I am an accounting staff to a big company, and I used QuickBooks most of the time.
But this morning when I run it on my laptop I got this error.
How can I QuickBooks as not administrator?
Because the message means that I should not run as administrator?
Please tell me what to do.
[FSLB-363]
There is an error starting QuickBooks.
Please restart your QuickBooks.
If you are running QB as Administrator in Windows Vista of Windows 7, please close the company file and open the company file normally
OK
Answered By 5 points N/A #118713
Just simply check the software if there an error from the file maybe the file has been corrupted or lost from the system just check that one to see was problem to your software and then if you like just search from the Quick Book in the knowledge base then try to uninstall the software and then reinstall again and simply check or scan the system if there an viruses that can infected or maybe effect to your system just simply check that one and then try to check the software if its suitable to you operating system just check on that.
Ben
