Fujifilm X-Pro 1 mirrorless camera
The X-Pro1 is a mirror less camera. It is the start of an all-new camera system, with a brand new mount and lenses. Why this is called mirror less camera which makes it different from other camera brand?
Hello there!
Price wise, the Fujifilm X-Pro 1 is a little bit expensive compared to the other cameras which are dominant in the market nowadays. If you talk about usage of the camera, it takes a bit of "hands-on" time to actually get use to how the camera works and what settings you would like to use compared to the others out there. Mirrorless as it meant that it does not have a mirror-based optical view finder unlike a digital single lens camera. The X-Pro1 has a mirrorless interchangeable lens equipped with getting high ISO shots to low giving a high quality feature of the photo and can give a 1080p video quality. The camera itself has the image of a classic type camera attracting professional photographers and those who love taking photos.
Hope it helped.
-Francis-
