anonymous
7060 points
Posted on - 11/10/2012
Hi there,
I want to know how i can take a picture with my pc ( Fujitsu LIFEBOOK AH531)camera? I can take a snapshot by using Skype but if there is possible to take picture in different way,
Is there any program in PC..?
Fujitsu LIFEBOOK AH53. How take a picture?
When you bought your Fujitsu LIFEBOOK AH531 supposed to come with a Driver CD. If you have that CD, Please Install the camera driver for your webcam. Then you will be able to use your webcam.
If you don’t have the Driver CD, I am giving you the download link you can download it from here:
http://support.fujitsupc.com/CS/Portal/driverdownload.do
Have you installed a driver for your webcam? To check this, right-click on my computer then select properties. In the window that appears, select device manager and on the new screen that appears, it shows all the devices currently detected by BIOS or rather your computer.
Check any device list with a yellow marker. This means that device’s driver has not yet been installed. You can try and update the driver automatically to try and search windows update for a match of the driver. If you are not connected to the internet, you can load the CD or DVD or the drivers provided by the manufacturer of your computer.
If you find no yellow marker or you find the webcam driver is installed, try the link below to download the updated driver that shall help you interact with your webcam;
https://www.notebook-driver.com/fujitsu-ah531-notebook-win7-64bit-drivers-utility/
Choose the link with Camera Driver (For model with Fujitsu WebCam module) and start the download. After the download, install the driver and check the my pictures folder in library to see if there is a webcam option. Normally, it is found in my pictures or my videos folder in the library of your computer.
I hope this helps you.
