Fujitsu’s built-it-yourself to offer computer service
I heard that Fujitsu will start offering a build-it-yourself service. While the motherboard is already installed, they will teach how to install the other hardware components of the one's choice. However, the classes are only available for Japanese consumers. Will they also consider extending the classes to other countries soon?
Answered By 0 points N/A #137386
Most big computer companies seem to be against the whole building your own custom computer idea  with the exception of allowing you to customize a couple of features that they have pre-selected, Fujitsu has decided to go against that concept with its new Hands-on Custom PC Assembly Service. Japanese citizens can take the class that helps teach them how to install processor, hard drives, and RAM from a limited selection.
The program would not be completely from scratch, as the motherboard will already be installed but it will take students through the whole process of building their own custom computer. Students will also be able to choose how many components they wish to add and can also learn important safety measures such as wearing anti-static wristbands.
This course will help make those who take it more comfortable working on the inside of a computer and will probably help relieve some of the technical support calls that Fujitsu receives. Hopefully other American PC companies will be inspired by Fujitsu’s actions and will offer a class similar to this or at least allow the option to custom-build your own PC.
