My tablet is a Fujitsu K704 that came with Win 8.1. The front camera does not seem to function properly. I used different apps compatible with Win 8.1 and it gave me the same problems. The picture lags and the resolution is too low. The driver was installed properly. Any ideas?
Fujitsu tablet’s front camera lags and takes lowest resolution
Ensure that the camera is properly calibrated and configured. Access the camera settings using your bundled OS and utilize the guided software. Please ensure that Windows is fully updated and check the OS website for device driver bundle downloads. Also, check the device manufacturer website for the latest drivers. If this does not solve your problem, your camera performance may be “choked” by bloatware and data issues. Perform system maintenance and/or seek a RAM upgrade.
