Function and Features of Avast Administration Kit
Hello friends,
Where can I find avast administration kit? I just installed my avast antivirus but doesn’t have any idea on the correct location of the administration kit, what is the main purpose of the kit and how does it work?
Thanks and Regards,
Davis Millers.
Answered By 0 points N/A #180918
If you already installed your anti-virus, the Avast anti-virus and it is working properly then all other stuffs that comes with that anti-virus is already installed too.
To see where you can find the avast administration kit, you can go to the program files.
Just go to your local disk then go to program files and look for that file.
Or you just search it by using your search button.
