Function to open new window in PHP
Hi! I’m a beginner in PHP. I want to know any function for opening a new window using PHP codes. Could anyone give me a hint for this? Many Thanks.
Hi there Noel Leal,
I understand what you'd like to achieve, but unfortunately, you can't do this using only PHP – you will need some JavaScript too. The thing is that PHP is a server-side technology, while you are trying to do something on the client side (opening pop-up window).
Here is a simple JavaScript that you can simply copy and paste into your code that will open the pop-up window using the window.open function:
echo "
<script type="text/javascript">
<![CDATA[
function show(rowid, arrno) {
window.open(
'Name',
'status=0,width=100,height=100'
return false;
</script>";
Best regards,
Drake Vivian
Greetings Noel Leal,
I don't think it's possible to use this with PHP only.
Rather you need to use something like Javascript or jQuery to get this done.
Like on example Javascript or jQuery
This script is good as you see there are values you can easily change for your new windows. You can set it's dimensions, does it have a scrollbar, toolbar etc. The website Techyv should be the website you want to be opened.
It is generally better not to echo your scripts from PHP. They should rather stand on their own.
I hope this solves your problem.
Hi New to PHP app.? Same here and that is challenging. I've been researching different forms of opening new files in PHP. Here are some ways to do: The Read-'are', the 'w' and the append 'a' From the 'r' form is read only. From the 'w' form is write only. (Will done in the beginning of the data) From the 'a' form writes also bought (well done in the end writing of the data) checked this sample form: q and if you want to read and write data just insert '+' this sign to allowed you to read and write data. sample form: $ourFileName = "testFile.txt"; $fh = fopen($ourFileName, 'X') or die("Can't open file"); fclose($fh); Good luck. Thomas
