Function of Virtual Private Server on Securing a Website
I have my own website now i want to secure my website form cyber criminals. For that purpose i want to use Virtual private server  for my web. Can anyone tell me about the Virtual private server benefits for web.
Answered By 20 points N/A #193626
Hi Ruiz,
The name Virtual Private Server provides its own definition by just looking at their terms. It provides you an environment which runs like an emulation.
As for the advantages, you can consider your site secured since the VPS comes with piles of security protections. Therefore, it is not likely for you to be banned in sites. You can manage more the content since you “own” it. And, the speed will not be questioned. You own your server so it is likely to happen that any connections are only coming from your website. Speed is reliable.
With VPS, you can also edit, load, and manage your own settings.
I hope this helps.
Diane
