I am having some functional error with Microsoft office 2007. Earlier I could enter the office word from start menu Microsoft office option but now for some reason all other office contents are showing the office word. I need to get it back to the menu. Should someone know of this problem kindly inform me about the problem.
Alonzo Smith
Functional error with Microsoft office 2007 – office word
There are some points for you about your recent problem:
1. You can enter the office word from start menu Microsoft Office option. You can also enter different office program by right clicking in a folder even on your desktop. Check here to find all other office content.
2. If all other office contents show the office word – they may be corrupted with some other programs or virus.
3. The way, you remove your office program and install it again to solve your problem. You should observe carefuly while installing software. It must be compatible with your current configuration.
4. Get your Antivirus updated.
I hope you understand it.
Thanks
