Functions and Usage of ResourceFilter 1 Software
According to my opinion it is quite handy, simple and small sized software with many facilities. For me it is a very useful one. I would like to know what is your idea. Thank you.
I think this is a good software too. I will list some of the uses of it as an useful application.
* Can add and remove filtering fields according to our choice through available attributes.
* It allows not only single files but also allows you to filter entire file directories.
* Can prepare files individually like the flash movies with the help of advanced functions.
* The design of the resource filter is much more attractive than other software.
* It is easy to use with simplicity and also it is a free software, but only for the registered users.
