Functions For Nec Dsx 80 Phone System And Its Key Features.
Hey, what is the price for nec dsx 80 phone system also notify its key features for the same. Thank you for solving the issues.
Hello, the price for nec dsx 80 phone system ranges from 12k-24k depending upon the type of hardware you select and the necessary hardware you require for the same. It is present over the online portals like Amazon and can be bought from there too easily without any harm. The key features for the same are as follows:
• It mainly consist of 4 slot of cabinet
• Also includes 8 CO card line
• Also has the process unit and the power supply as well
• It has 16 port digital card extensions.
• The VoIP is compatible up to 32 IP etc
Notifications
