FX composer 2.5 and Shader Debugger errors
 I have tried to install FX Composer 2.5 and a Shader Debugger on all our office workstations. When I tried to run them, I got the error message below. I have tried several things including reinstalling the Operating System and disabling Kaspersky but I still have the same error. How can I have this resolved?
 Our workstation specifications are;
Computer Model: Precision WorkStation T3500
OS: WinXP Pro, SP3
CPU: Intel® Xeon® CPU W3505 @ 2.53GHz (2 CPUs)
RAM : 4GB RAM
DirectX Ver. : DirectX 9.0c (4.09.0000.0904)
NVIDIA Quadro FX 1800
Display Memory: 768.0 MB
Driver Version: 6.14.0012.5849 (English)
Answered By 0 points N/A #135834
To fix these errors, you will have to blame NVIDIA because their drivers have not been updated so far. This error can be solved by switching from OpenGL to Direct3D9 to Direct3D10. You can see it on the corner that is present in the taskbar. You will have to un-install and then re-install this program when your PC does not contain any of the DirectD9 or Direct3D10. Both of these programs are exactly like that of OpenGL.
