FXCexe utility fails to load some shaders
Hi there,
I am using a FXC.exe utility from the Direct X SDK to load some shaders for a game. After I did that this big error appeared and blocked me. I don’t know anything about what it is said here. Can anyone enlighten me about this error and what it means ? How can I fix this and how to avoid it in the future ?
Thank you !
Message
Diect3DDevice -> CreatePixelShader(DWORD*)&Code(0),(lDirect3DPixelShader9**)PixelShader.GetlnitReference() failed at R:WILLOW2-PCORCHIDTULIPDevelopmentSrcD3D9DrvSrcD3D9Shaders.cpp:20
with error 88760028
RaiseException() Address = 0x7c81 2aFb (Filename not Found) [in C:WINDOWSsystem32kernel32.dIl]
AK:: SoundEngine::StartOutputCapture() Address = Oxl 161 b63 (Filename not Found) un C:Program FilesSteamsteamappscommonBorderlands
2BinariesWin32Borderlands2.exe]
GetOutermost() Address = Ox9ecda2 (Filename not Found) [in C:Program FilesSteamsteamappscommonBorderlands
2’sBinariesWin32Borderlands2.exe]
GeLD utermost() Address = 0x8b891 b (filename not Found) [in C:Program Files’sSteamsteamappsS.commonBorderlands
2BinariesWin32B orderlands2. exe]
AK::SoundEngine::StartOutputCapture() Address = Oxl 21 ba67 (Filename not Found) [in C:Program FilesSteamsteamappscommonBorderlands
AK::SoundEngine::StartOutputCapture() Address = OxFl 1 b7b (Filename not Found) [in C:Program FilesSteamsteamappscommonBorderlands
GetDutermost() Address = 0x71 F6c1 (Filename not Found) [in C:Program FilesSteamsteamappscommonBorderlands 2BinariesWin32Borderlands2.exe]
AK::MemoryMgr::SetPoolName() Address = Oxi 345129 (Filename not Found) [in C:Program FilesSteamsteamappscommonBorderlands
2BinariesWin32Borderlands2. cxc]
GetDutermost() Address = OxbOdad9 (Filename not Found) [in C:Program FilesSteamsteamappscommonBorderlands
GetDutermost() Address = Ox8eSFc8 (Filename not Found) [in C:Program FilesSteamsteamappscommonBorderlands 2BinariesWin32Borderlands2.exe]
Address = 0x6339a3 (Filename not Found) [in C:Program FilesSteamsteamappscommonBorderlands 2BinariesWiin32Borderlands2.exe]
AK::SoundEngine::StartOutputCapture() Address = OxedFOaO (Filename not Found) [in C:Program FilesSteamsteamapps’scommonBorderlands
AK:: SoundEngine: :StartOutputCapture() Address = Oxl 038201 (Filename not Found) [in C:Program FilesSteamsteamappscommonBorderlands
AK:: SoundEngine::StartOutputCapture() Address = Oxl 1 3Fe34 (Filename not Found) [in C:Program FilesSteamsteamappscommonBorderlands
2BinariesWin32’sBorderlands2.exe]
AK::SoundEngine::StartOutputCapture() Address = OxF4SaaO (Filename not Found) [in C:Program FilesSteamsteamappscommonBorderlands
2BinariesWin32Borderlands2. exe]
GetS tackO wnerClass() Address = OxcFF7e5 (Filename not Found) [in C:Program FilesSteamsteamappscommonBorderlands
AK::SoundEngine::StartOutputCapture() Address = OxF4c45d (Filename not Found) [in C:Program FilesSteamsteamappscommonBorderlands
GetOutermost() Address = 0x9e757e (Filename not Found) [in C:Program FilesSteamsteamappscommonRorderlands
AK::MemoryMgr::SetPoolName(] Address = Oxl 2eF4eF (Filename not Found) [in C:Program FilesSteamsteamappscommonBorderlands
AK::SoundEngine::StartOutputCapture() Address = OxF83FdS (Filename not Found) [in C:Program FilesSteamsteamappscommonBorderlands
AK::SoundEngine::StartOutputCapture() Address = Oxl 0c881 8 (Filename not Found) Un C:Program FilesSteamsteamappscommonBorderlands
GetDutermost() Address = OxS8ce7F (Filename not Found) [in C:Program FilesSteamsteamappscommonBorderlands 2BinariesWin32Borderlands2.exe]
GetDutermost() Address = 0xb2492c (Filename not Found) [in C:Program FilesSteamsteamappscommonBorderlands
2BinariesWin32S.8 orderlands2. cxc]
Pl8Getlnterlace() Address = Oxi 601 0F7 (Filename not Found) [in C:Program FilesSteamsteamappscommonBordcrlands
RegisterWaitForlnputldle() Address = 0x7c81 7077 (Filename not Found) [in C:WINDDWSsystem32kernel32.dll]
OK
