G Spot.exe has generated errors and will be closed by windows
Hi people.
I keep on receiving a GSpot.exe pop-up systems error. What is it and what causes it?
Some say it has something to do with a certain “.dll” file and could ruin programs in your computer.
Is there truth to this?
Program error
G Spot.exe has generated errors and will be closed by windows.
You will need to restart the program.
An error log is being created.
Answered By 5 points N/A #176817
Hello Vernon
I might be able to help you with this issue. First of all, you should just close the GSpot.exe from the Task Manager.
Press CTRL+ALT+DELETE and in the Processes tab, locate Gspot.exe and press Delete.
After this is done, you should scan your computer with your antivirus and see if the GSpot is infected.
Another thing you can do, is go to Control Panel > Uninstall a Program and remove the specific file.
Also, in there, uninstall Visual Studio C++. Reboot your computer and reinstall the software.
I hope you will find this information useful.
Randolph
