GA – 970A – UD3 motherboard problem
Hello friends,
I have recently started using a GA-970A-UD3 motherboard and it is working awesomely. Actually I am new at this stuff and I want your help. Actually I wanted to over clock my CPU for the first time.
To do so, I read a lot of posts and forums of which some were helpful and some were not. I have not yet over clocked it. So far I have just changed the CPU multiplier, VCore and the NB frequency.
I have attached the screenshot of what I am currently running:
I used prime95 for 6 hours to detect any errors if the over clock is not stable. Unfortunately an error was detected on 1 core at 4 hours.
Can anyone suggest how to remove that error?
Waiting for your suggestions.
Thanking you loads.
Jack
